12-10-2011, 05:39 PM
Originally Posted by FXSTi
Aglie,
Ya made me go check, my fuel cut off is at 8 and my calibration is 1.17. I posted in another thread a few minutes ago that it was at 1.16 but I had to see what my cut off was at so I went to look.
OK, then we are now at exactly the same settings, and this is good news because it probably means that all Fiestas can use this setting, or at least 2011 5-speed hatches.
Note: when you do the calibration, it prints its estimate of gallons used and lets you change that to reflect actual gallons used. Once you enter it, it prints the calibration fudge factor. But you can keep tweaking the number of gallons and it'll keep telling you what that makes the fudge factor until you get it to the magic 1.17 value (assuming you also set deceleration fuel injector cutoff to 1.6 liters and use 8 for its fudge factor).
