Go Back   Fiesta Faction > Faction HQ > The Eco Fiesta Driver
Old 11-22-2011, 01:21 AM
Default any advantage to running a higher octane?
Here in Ca I run 87 in the car which is what ford recommends. Is there any upside to running a tank of 91 octane other than it sucking cash from my wallet faster?
- 2012 Oxford White Fiesta SES Hatchback -
K&N airfilter
Old 11-22-2011, 05:48 AM
Nope. The reason there are different octanes is because of the different compression ratios in engines. An engine with a higher compression ratio needs higher octane gas to help prevent pre-detonation before the piston reaches it's TDC (top dead center) in the cylinder. Octane rating has nothing to do with power as some people believe. Some people swear they get better mileage with premium. Sure maybe they do because it is a higher quality, has more detergent or has less Ethanol at that particular station. I've never noticed any better mileage when I've tried using a higher octane in my other cars.
2012 Focus SE/Sterling Grey/6-speed auto/Sport package/winter package/Rapid spec 203A
Old 11-22-2011, 06:26 AM
emm, sorta.
This topic has been discussed before, just search.
FWIW, i run super.
Old 11-22-2011, 08:15 AM
our Fiesta 1.6L engine has a 11.0 to 1 compression ratio. Fiesta Movement [EU] Fiestas required premium fuel.
you may benefit from premium. maybe not better fuel economy but more power if it advances the timing to make use of more octane.
