Go Back   Fiesta Faction > The Faction Styling Center > Exterior Modifications
Like Tree5Likes
Old 08-07-2011, 06:04 PM
Default How To: Install LED License Plate Lights
You will need:
Two 5LED T10 bulbs. I got mine here. Anything brighter is too bright.
A flat-head screw driver.
10 Minutes.
Process is the same on the sedan as the hatch. Thanks SportsComedian!
Look for the light housings above the plate.
Slide the screwdriver into the small opening on the side and push back.
Once you get it slightly out you should be able to pull it with your hand the rest of the way.
Now start to twist the round plastic cap attached to the plastic box till you can remove the box. I can't remember if it's clockwise or counter clockwise but you'll know if your turning it the right way.
The easiest way to get the bulb out is to use a rubber grip for opening cans and jars. I didn't want to shatter the glass with my fingers.
Now take your new LED and push it into the socket. NOW THIS PART IS SUPER IMPORTANT! Turn your lights on and make sure the LED works before putting it back together. If the LED is in backwards or isn't seated all the way it won't light up. So make sure they work, then turn the lights back off and put it all back together.
And here's the final result!
Hope this helps out!
brbauer2 likes this.
Candi
2011 SES
LEDs 20% Tint Red Logos Chrome Exhaust Leather Shift Knob K&N CAI
Old 08-07-2011, 09:30 PM
Thanks for the write up and pictures. Is the light brighter or the same?
Bill
Monterey Grey w/Lt Stone sFe Hatch
Automate the manuals
2009 Prius Grey
Old 08-07-2011, 09:37 PM
It's a bit brighter, the main thing is it looks so much whiter with the LEDs. You can always do a six or eight LED bulb if you want something super bright.
wmussatto likes this.
Candi
2011 SES
Old 09-21-2011, 07:04 PM
Confirmed. Process is the same for the sedan. Just did it and looks awesome.
Old 09-21-2011, 07:08 PM
It's a very easy process and it does brighten up the license plate so cops can see it better Just be careful when removing the OEM bulbs.
'11 SE Sedan
5% Tint, Black Tails & Grill, Interior Trim Kit, K&N CAI,1100W Sub & Amp
Old 09-22-2011, 07:46 PM
Well you could always just use two 2LED bulbs instead, or just take them out when you go street racing .
Candi
2011 SES
Old 11-30-2011, 01:35 AM
did the mod tonight, took all of 10 minutes and looks 10x better. Thanks!
- 2012 Oxford White Fiesta SES Hatchback -
K&N airfilter
Old 12-02-2011, 11:32 AM
just ordered my leds im stoaked. And i should be able to install them in between games on mw3. i think im gonna have to order one for the hatch light now. Thanks for the idea
Ses violet grey
Old 12-02-2011, 11:38 AM
Glad to hear it! The interior map and dome lights use the same bulb, switching those with LEDs makes a huge difference too.
Onebrownguy likes this.
Candi
2011 SES
Old 01-18-2012, 03:55 PM
Location: 40 miles from downtown Chicago, pick your direction.
Just did this today and have to wait for nightfall to see the results.
Very easy to do. Took all of 10 minutes.
I’m thinking about 'modifying' the interior of the black plastic housing with some aluminum foil to reflect some more of the light out, but that is for another day.
BEFORE:
AFTER:
SEL4ME and appleinfl like this.
2012 Red Candy Fiesta SE 203A PS — K&N Intake — FordRacing Suspension — MAGNAFLOW Exhaust
