Old 02-18-2010, 11:49 AM
Originally Posted by iamz View Post
"....Still wondering what to do with the TPMS sensors."
I'm wondering about that to.
Most likely you will have to get another set. But always remember that I can also get you awesome prices on Ford parts. We use a huge worm clamp along with OEM sensors here all the time with no problems at all.
Bill Jenkins
Sales/Internet Manager
Team Ford, Las Vegas
#1 dealer in Nevada 2008 & 2009.
Follow us on Facebook (CLICK)
Old 02-18-2010, 12:10 PM
the Fiesta will use a TPMS sensor mounted on the valve stem, behind the rim of the tire. The whole TPMS thing really messes up my winter/summer tire deal and I consider the system stupid. It means more people won't use proper tires for conditions. This is an issue in the snowy climates were I see snow tires becoming more common on cars. We have TPMS on our Escape, and the only time the light triggers is when the sensor goes silly. I wish there was a more cost effective way to employ the system for people who use multiple sets of wheels and tires. Currently, it is very pricey. Last time I checked, the sensors would cost just about the same as summer tires, not including the programming cost. Each time I swap between seasons, it is another trip to get it reprogrammed, or buy a programmer.
Old 02-18-2010, 02:07 PM
Is it possible to just not program the system and deal with the light being on all the time?
Old 02-18-2010, 03:09 PM
Already discussed with people in the know, and you can't undo the TPMS system since it is mandated by the feds. Discussed a track programmer that can be plugged in to defeat traction, stabality, and TPMS for track use only. Feds would not like the idea of turning the system off.
Old 02-18-2010, 05:21 PM
We used to sell a programmer for the E-150 that would let you reprogram the TPMS by yourself. It cost about $20 or so.
8C2Z-1A203-A is the part # @ Team Ford Parts Online- Ford OEM Parts at a discount
Bill Jenkins
Old 02-18-2010, 05:37 PM
I know it is a federal mandate that cars be built with this system. But what does the mandate say about end user modication? I don't know the wording of the law, but I know people who did not replace their airbags after an accident and of course you don't have to drive a mile to see someone who is missing their 5 mile per hour bumper.
  #17 (permalink)
Old 02-19-2010, 12:11 AM
how wide are the Fiesta 16" wheels? 6.0" or 6.5" ?
  #18 (permalink)
Old 02-19-2010, 01:27 AM
The Fiesta uses 4 x 108 wheels. I am using a set of 2001 Focus wheels for the winter, and I test fit my 17" Focus wheels on the Fiesta this summer.
I have a set of 17" early SVT Focus wheels and am dying to see how they look on the blue Fiesta, if there aren't any fit issues that is.
  #19 (permalink)
Old 02-19-2010, 08:22 AM
you will need to step down a tire size if you are using 215/45 17 on the wheel. I put my 17" Axis wheels on the Fiesta and noticed there is about a half inch gap between the tires and the fender when using the 215/45 17, so I am going with either a 205/40 17 or 215/40 17. Both tires will be very close to the same diameter as the stock 16".
  #20 (permalink)
Old 02-19-2010, 10:21 PM
Yes if you put aftermarket wheels on that don't have the TPMS sensors then the low tire pressure light or warning will just stay on. However if the Fiesta uses the TPMS sensor style that is part of the valve stem all you need to program that style is a circle magnet that has a whole in the middle that will go over the valve stem.I use one that is found in transmission panels that collect metal in the trans pan but you can find them at stores I am sure. To put the system in program mode you cycle the key 3 times within 10 seconds and after the third time leave the key on and press and release the brake pedal,the horn will beep and the message center will say program LF wheel. You then take the magnet and put it on the LF valve stem and wait till the horn beeps again and then put the magnet on the RF,RR,LR in order and wait for horn to beep on each wheel before moving to the next. After all wheels have been programed the message center should say programming complete. If they use the band type sensors then the program steps are the same except it uses a special programming tool instead of a simple magnet.
