Old 12-18-2010, 12:34 AM
tjl tjl is offline
The OBD-II port is under the dash on the driver's side.
Old 12-18-2010, 12:40 AM
Thanks so I assume that UltraGague is the one talked about here?
Old 12-18-2010, 10:42 AM
Originally Posted by larrylwill View Post
The ultragauge that is on sale at Ultragauge.com, will it fit the 2011 Fiesta? It doesn't say on their web site. Where is the OBDII port on the Fiesta?
Thanks
It has been installed on my SES 2011 Fiesta Hatchback since first week of October and works great. See past posts on this thread for more info.
Old 12-24-2010, 06:35 PM
Installed my Ultragague today. Works great.
Question: Where does other owners mount it on your fiesta?
I stuck mine just to the right under the speedometer. The sticky tape doesn't stick to the dash soft plastic.
Old 12-24-2010, 10:40 PM
I put an Ultragauge it in a couple of weeks ago. I used the suction cup/gooseneck mount. I mounted the suction cup to the little glass triangle in front of the A-pillar, made a 90 degree bend in the gooseneck, then put the ultragauge right above the left air vent. It's nicely out of the way and still visible.
I'm pretty impressed with the unit. I have a Scangauge II in my Jeep and did not want to pay another $160 for the Scangauge.
Delivered, 6/28, 2011 Flame Blue Hatchback SES, 301A, Moonroof, 5 spd
Old 12-25-2010, 09:40 AM
how good does it stick, or do you remove it when the car is sitting?
btw Merry Christmas
  #27 (permalink)
Old 12-25-2010, 10:01 AM
I tried to stick the provided suction cup and mounting devise on the small triangle of glass you speak of, but I couldn't get it to work. I mounted mine to the far left of the windshield and bent flexible stalk so it is right out of my line of sight when I drive, but only takes a small movement of my eyes to see the gauge. When summer comes I will probably move my UltraGauge to the area above the steering wheel or down in front of the shift lever. It does have a built in alarm that sounds when it gets 150 degrees,(I have black interior) but I want to move it before it gets that hot. I really like my gauge. Especially the engine water temp and the barometer. I can also see exactly how many gallons of fuel remains in the tank instead of guessing. Many other good features to numerous to list.
  #28 (permalink)
Old 12-25-2010, 10:07 AM
How did you like the way you had to get to the rebate and how many hoops you had to run through to get the info?
  #29 (permalink)
Old 12-25-2010, 10:14 AM
I felt the gauge was such a bargain and did so many things that the price was a bargain without the rebate. My time is too valuable to spend the time to "jump thru the hoops" they asked. Other gauges I looked at were over a hundred or two hundred dollars higher in price. I'm wondering when the price will increase?
  #30 (permalink)
Old 12-25-2010, 10:16 AM
I just wish I would have known about it while the price was $39
