I'm thinking of picking up a fairly lightweight set of aftermarket wheels and would like to mount some 205/50-16 LRR tires on them.
What's been your experience with LRRs? Any significant MPG gains? Any downside like maybe less grip or rougher ride, etc? |
Internal friction is one of the primary areas for improvements, which can lead to improved gas mileage without much trade-off, but the tread compound can also be changed for less rolling resistance which could involve a trade-off in grip under braking and cornering. Is it worth the difference? That depends on how you balance fuel economy vs. performance and/or safety.
Trevor Tire Rack O: 888 428 8355 ext. 795 O: 574 287 2345 ext. 795 [email protected] Remember to reference Trevor/FiestaFaction in the "previous contacts" field to make sure the forum get's credit! |
Good to know. I plan on driving with the LRRs from maybe April thru November with no plans of autocrossing this car (I do that with my Miata). So I would think for everyday driving they should be fine.
Here are two...
Goodyear Assurance Fuel Max Bridgestone Ecopia EP422 Remember to place your order through the link to help support the forum!
There is a ton of info over on priuschat.
Won't be apples to apples due to CD and all that but if something does well on a Prius it will do good on a Fiesta. Generally the fuelmaxes are considered the best, but also the priciest.
Founder of The Poop Sock TM © Patent Pending and all that. |
Lot's of variable come into play, but the goodyear was the most fuel efficient in our testing.
