I would like to hear what people have to say. Our cars use a multi weight oil. That's because we drive our cars in all kinds of temps and weather conditions. The oil needs to be viscous at varying temps. Makes sense.
Now my question. Why do lawn mower engines specify just plain 30 weight oil and do not want us to use a multi-weight? I understand that we use our mowers mainly under the same temp and weather conditions and a multi weight isn't necessary. But, what harm will it do if we do use a multi weight oil such as 10w-30 or 5w-30? And another question...Any reason that we can't use syn oil in our lawn mowers?
Actually, the newer engines for mowers specify 10w 30. Years ago 30 weight was the standard because most mower are used in hot weather. Also, you can use synthetic as well. Briggs and stratton actually wants you to use this. Check your specific motor for proper weight ect but nothing is stopping you from using 10w30. I have used 5w 30 mobil one synthetic for years in a Briggs Vanguard.
![]() But yeah, my mower is a 1 year old Craftsman with a 6.75 B&S and uses plain old 30 weight.
I'm going on the B&S web site and see what they say about syn and multi weight. However, I also use a multi-weight oil in my own mowers and have not seen any ill effects. My main reason for asking is that many customers come in and ask what oil to use for their mower. Store policy says we must tell them SAE30. But that bothers me and I want to tell customers the correct info or any options. If I can get manufacturer proof that multi-weight is OK I won't get into trouble by offering an alternative. Price does not seem to be a point...our lawn mower oil is priced higher than most oils per quart!
2011 Blue Flame Metallic SE Fiesta Pwr Shift 6 Spd Auto Charcoal Black w/ blue cloth and armrest. Last edited by Norm201; 05-20-2011 at 07:51 AM. Reason: added price comment. |
I would've expected you to mod out your mower. Say perhaps custom wheels and chrome tip exhaust. Be sure send pics when you do it!
My dad told me he never changed his oil and owned his mower for 15 years so I am seeing how that will work out for since the whole setup is stupid (having to basically tip the mower over to change...or use a vampire pump).
So my answer...WGAS?
Founder of The Poop Sock TM © Patent Pending and all that. |
Tipping mower over to drain the oil was never a very good method even though they suggest that as the way to do it. All the mowers I worked on have a drain plug on the under side of the mower housing. Makes draining very easy.
I haven't gone to any manufactures web sites yet, but here are some of the feedback I've gotten from my work associates.
The best comment...Not necessarily including riding mowers most mowers do not use an oil pump, but a splash system to get oil to the cylinder heads. Single viscosity oil in normal grass cutting weather will insure better lubrication at start up. Other comments...Mower engines are not made with the same materials as car engines and the multi-weight oil additives will harm rings and seals. I don't totally buy into any of these reasons. BTW...My generator uses a Subaru engine and they also specify a straight 30 weight oil. And that;s for use in any weather conditions.
Just went to the B&S web site. This is their recommendation:
Category: Print Answer Email Answer Share | Was this Helpful?Yes (52) No (6) Engine Oil Recommendations What are the oil recommendations (type) for my engine? For information regarding the oil capacity for your engine, please visit our Oil Capacity FAQ. Oil Recommendation
