Put car into 2nd, then shift into Reverse, pull handbrake (unless brakes are hot), and then shut the engine off. For starting, I put on my belt first (as I found it turns of the dinkle-dink buzzer), clutch in, start, handbrake off, and either back-up or put it in 1st.
Now, my Mustang is a little different for parking. 1. Locate flat area since the car has no handbrake 2. Put car into 2nd, then into Reverse 3. Flip ignition master switch to off 4. Turn fan switch to off 5. Turn guage switch to off (turns off gauge cluster) 6. Turn key to off position 7. Release key back stop and remove key 8. Turn cam-lock to release the belts 9. Climb over the roll bar and get out 10. Cycle battery main cut-off switch to the off position
1) With one foot on the clutch, and the other on the brake,
I shift the car into 1st. 2) Then set the parking brake. 3) Then turn off the ignition. 4) Then take foot off the brake 5) Then take foot off the clutch I ALWAYS set the parking brake when I park my vehicles. It is, probably, because of this that the parking brake on my 1989 Corolla never seized up once in the 21 years I owned it.
2011 Red Candy, 5spd manual, Fiesta SE Hatchback Last edited by IB-5; 09-03-2010 at 04:37 PM. |
Never using your parking break will surely lead to seized cable or broken linkage. Always using PB will keep it going in good working order until mechanical usage just wears it out (most cases the cable breaks). Better to wear it out. It makes for easier replacement.
Set e-brake. Turn of ignition. Just by virtue of having toe negotiate the parallel parking, the clutch is usually depressed until I kill the ignition.
2011 Yellow Blaze Metallic SES AFN 2011 1st Place Fiesta Focus Rising 2011 Winner Best Fiesta |
A question for the PowerShift crew... I've noticed a couple times, usually if I turn off the ignition immediately after shifting into park, the car may roll several inches before I hear a audible "click" from the transmission or engine area and then the car will stop. Has anyone else has this pop up?
My theory is that I was too fast for the computer to properly "park" the transmission, however it's handles in the PS tranny... Though I've now gotten into the habit of applying the handbrake when I park.
Domina; a 2011 Fiesta SES http://www.socalfiestas.com SCF is on Google+! "It's a Fiesta thing!" |
I now tend to come to a complete stop, shift into reverse (or park or drive) and wait a second or two before moving the car or turning off the engine.
2011 Fiesta SES Yellow Blaze - Charcoal Leather - 301A - PowerShift - Moonroof
2011 Silver Ingot Fiesta Sedan SE w/ Sync Package |
Exactly what I do.
I've lived in the snow and rust belt all my life. (51 years) Never had any problems, alway set parking brake. It's when you never use it the cable and parts rust up and stick. This is an important safety feature. I put it in first and set the partking brake with my foot on the brake and turn off the engine. I had a neighbor who's car rolled down their driveway into the street when it was in park.
Dan 65 Corvair convertible Hibernating![]() 11 Fiesta SE Sedan, 5 speed, white
