Old 02-01-2012, 02:23 PM
Default no place/water shortage, the rinseless wash is the solution!
So I feel like I should help you out here ! Many people complain they dont have space,water faucet outside or they have hard water, well you should use the twin bucket rinseless washing method with specifically engineered soap which uses polymer to encapsulate dirt particule. The most known are optimum no rinse and DP rinseless.
I am posting here a couple guide to ONR and DP for your help
you can also buy these products at any online detailing business (or directly from optimum in the onr case) to name a few that i know : autogeek.net, eshine.ca
written guide:
Rinseless Wash How-To
Step 1: Insert your Grit Guard insert to the bottom of your bucket
Step 2: Fill your bucket with 3 to 4 gallons of warm water
Step 3: Pour in 1 oz of Optimum No Rinse per 2 gallons of water in your bucket
Step 4: Soak your wash media in the water and ONR solution
Step 5: Wash the surface using little to no added pressure and allow the ONR to lift contamination off of the surface
Step 6: Rinse your wash medium and glide it across the Grit Guard insert to help release as much contamination as possible
Step 7: Repeat steps 4 - 6 until your entire vehicle has been washed
Step 8: Blot dry using waffle weave drying towels
Step 9: Follow up with your choice of quick detailer and a plush microfiber towel to ensure no streaking or water is left behind
Note: On heavily contaminated vehicles, we recommend pre-treating the panel you are working on with a mixture of ONR in a spray bottle, prior to washing. This will help lift the contamination prior to touching your vehicle, helping minimize adding any imperfections to the paint.
pictorial:
detailien.com- Optimum Car Care Malaysia: Optimum No-Rinse (ONR) Guide with Optimum Opti-Mitt and Optimum Opti-Seal
Car detailer: waterless rinseless car wash, green car wash
video with mike phillips
part 1 :http://www.youtube.com/watch?v=XvhyJix0IVs
part 2 : http://www.youtube.com/watch?feature...&v=VmXZG85dByk
hope it helps you out
