Can't add gas... Pump constantly shuts off
Fiesta Faction - Ford Fiesta Forums
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Apr 2012
    Posts
    382
    Default Can't add gas... Pump constantly shuts off
    Thai has been discussed before, but....
    This use to be an intermittent issue in the winter on my '11 SES. Now I spend 15 minutes at the pump filling it up, holding the pump at 1/4 throttle every time I fill up.
    God damn POS Ford!
    Anyone have a way to circumvent the charcoal filter or venting somehow?
    On a positive note, I can now actually FILL my tank to full... Previously when the pump auto shut off the way it should, the gauge would always read just 4/5th full (and I read there was a TSB for a gauge issue not reading properly, and just assumed it pertained to me.)
    Nice to see that now I can get another 70-80km more out of a tank of gas!
  2. #2
    Join Date
    Apr 2012
    Posts
    382
    Nobody....?
  3. #3
    Join Date
    Dec 2016
    Posts
    6
    Quote Originally Posted by WuNgUn View Post
    Nobody....?
    Don't have any fixes for ya but, my sister in-laws 11' hatch does the same goofy stuff and her check engine light comes up periodically for it evap leaking aswell.
    Sent from my iPhone using Tapatalk
  4. Remove Advertisements
    FiestaFaction.com
    Advertisements
  5. #4
    Join Date
    Jan 2015
    Location
    SL,UT
    Posts
    172
    Mine has been doing it since I bought it new 2years ago. Never had the time or money to get it fixed... I don't know why they made a crappy venting system for it....
  6. #5
    Join Date
    May 2015
    Posts
    5
    I have this problem and never fixed it either. When I get gas I use my house key to prop open the fuel handle just enough to fill it so it doesn't shut-off. Usually takes about 5-6 minutes to pump a full tank. It sucks, but not worth the $400 or whatever someone said it costs to fix it.
  7. #6
    Join Date
    Sep 2012
    Location
    New York, NY
    Posts
    33
    The filling up issue has happened to me just a few times, and I think it's always been with the same gas station (BP). Does this happen to you no matter the gas station? What about the particular pump?
  8. #7
    Join Date
    May 2014
    Location
    Fairbanks Alaska
    Posts
    88
    I think that happened to me once. I blamed the gas station pump...
    Tall Timbers
    Tuxedo Black: 2X 2014 Ford fiesta SE 1.0 liter Ecoboost & 1X 2011 Ford Fiesta SE
  9. #8
    Join Date
    Dec 2009
    Posts
    2,971
    In my case, there is absolutely no connection to the gas station or pump. I've tested it out by moving to a different pump at the same station and then drove down the street to a different gas station. Makes no difference.
    For me, it only happens after I've driven in the rain or through lots of standing water or slush. I'm not convinced that water is getting in the vent system though because I'm on the 3rd set of ventilation components and that's never fixed the problem. I think the electrical connection to those components doesn't like to get wet. The plan is to crawl under the car and water proof it. Then I'll test that theory out.
    For now, if there is rain in the forecast, I'll fill up beforehand.
  10. #9
    Join Date
    Oct 2014
    Location
    Berkley, MI
    Posts
    502
    Mine did that briefly a couple of times, but not since, however I've had a couple of P0456 codes pop up over the last month or so. After perusing the intarwebz a bit, my first guess was it's the silly cap not seating or sealing properly, so I used the funnel spout to rattle around the flapper in the cap. Also, each time I've filled it, I used the spout of the pump to do the same. I haven't seen a code in several weeks after the last couple of fill-ups. The cost for a plastic tube of coal is pretty ridiculous.
  11. #10
    Join Date
    May 2017
    Posts
    3
    Its your vent system for your gas tank, usually a charcoal canister type that gets clogged, or the valve malfunctions. Happened on other vehicles to me amd this was the fix!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
