Emergency! I’ve had a engine malfunction service now alert come up, with a spanner signal.Although my cars been serviced only last month. When turning the ignition on and off it disappears. Any advice?
It’s probably the service reminder that the dealer forgot to reset. First check if there are any codes showing:
Ford Fiesta MK7 hidden menu procedure
1. Press and hold trip reset button on the instrument cluster.
2. Turn ignition on with key or by pressing START button without clutch. After few seconds “test” message will appear on the display.
3. Release the button.
4. Browse the Ford Fiesta MK7 hidden menu with trip reset button.
If no codes then:
Resetting the Oil Life Monitoring System
Note:Reset the oil life monitoring only after an oil change.
1. Turn the ignition key to the on position. Do not start the engine. For vehicles with push-button start, press and hold the start button for two seconds without pressing the brake pedal. Do not attempt to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be displayed.
5. After 25 seconds, the Service: Oil reset complete message will be displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be displayed.
8. Rotate the key to the off position. For vehicles with push-button start, press the start button to turn the vehicle off
