2014 Fiesta sFe
My understanding is that the timing and oil pump belts shedding bits off and clogging the oil intake is a bit of an Achilles heel for these engines.
Tire Automotive tire Automotive lighting Motorcycle Wheel
Figure 1: An oil pump clogged with bits of timing belt.
Just want to report that this $16 endoscope does fit between the bottom of the pan and the intake screen.
Line Office supplies Metal Cylinder Titanium
It's a straight shot in through the drain hole.
Liquid Astronomical object Electric blue Space Circle
First you get a view of this little screen (whatever it is).
Not what you're after, keep going.
Automotive lighting Auto part Circle Automotive tire Automotive fog light
Here it is.
60,000 miles, still looking good.
The plan is to make this part of the oil change routine.
It takes a little longer because you will have to get the oil hot and then let it drain for a good 30-40 minutes with the nose raised up a couple feet.
Worth it for some peace of mind though.
