found a nice set of bbs wheels 15 x 7 or 8 guy is not saying with et33 will they work will they be in the wells or sticking out i can always get spacers if they are in the wells right ? Please help thanks
The 7's will be just about flush where the 8's will poke about a half inch. The upside with the 15's is you have a bunch of tire size options to tweak the look you are after
Being that close to flush you will need coilovers cranked down pretty low to minimalize body roll and to close in the wheel gap. Don't go larger than 205/50/15, tbh with this setup the lower profile the better for clearance
15x7/30mm offset is flush. 15x8/35mm is flush. Flush offsets locate the front rim dead even with the outer edge of the fender. You do not need spacers as spacers will move the wheel further outward. With a stock suspension, this will leave a well defined gap as a stock diameter tire will be very close to the fender and will give a "4x4" look. Solving the gap problem requires lowering as Messy Ford has said. Coilovers offer the best way to dial in as much drop as possible to solve the wheel gap problem and not rub. The 205/50/15, at these low offsets, as instructed by Messy Ford is the way to go.
Nice for stance. Although quite the extension past the fenders. Goes with the territory. The blanket statement it fits is but for a very small few individuals who want the slam/poke/stretch/stance appearance.
They fit. Hahaha. Sorry for the delay.
Some more high quality ones. I'm pretty sure I'm the first guy I know to get this aggressive of a fitment on coilovers around here. Maybe.
Related Threads
248.4K posts
12.6K members
Since 2009
A forum community dedicated to Ford Fiesta owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, and more!
