I've got the no engine turnover and no communication with the pcm problem with f27 open.
I took out the back seat of the car, as per these instructions, but I don't think I found my nvld.
Where's it at? Is it different for 5 doors vs 4 doors? Did I misread the service bulletin?
OK. I read what you sent and from my understanding you may or may not have an in line fuse. Per the instructions did you check the fuse in the main fuse box? If good then you need to determine if there is a wiring issue or possibly the fuse box itself.
