My 2011 had front brake vibration apparently due to factory pads. When I replaced with new factory pads, the vibration went a away but the came back. I read somewhere the factory pads get some kind of buildup on them causing vibration. Not sure what as might also be rotors but since vibration seemed went away with brand new pads i guess pads cause. Soooo, i now havea 2014 and same vibration. Will be changing pads. I always prefer factory pads in the past but will likely go if there is a consensus which brand type etc best. Only using street, no track. Rare used hard but will be once in while. Thanks for opinions etc
