It worked man. Both my grab handles are great now. I drilled a small hole and filled it with several screws.I had the same problem. I do feel like they should make a replacement part for the inner hassle that's attached to the door as it would bit be hard to replace. BUT since I couldn't find one without buying a whole new door handle I just pre-drilled done holes and threw four short roofing screws to hold it in. Seems to be working so far. I did have to take the washer off the top screw so the handle cover would clip on.
