Im curious if you ever got your setup running! I know you ran into issues with the fuel rail connections so I need to know!Dean72 gave me solid advice and told me to add nitrous. The reason nitrous will work in these cars is that because it is an oxidizer but does not add pressure to the manifold while still allowing the engine to burn more fuel. The MAP sensor in these engines will get angry with boost and force the throttle body to close down to compensate for the unexpected boost. You can "trick" the engine into making more hp with nitrous because it helps burn more fuel faster without making the MAP angry. You can view my build here . I'm almost done with the install and will be going to a dyno to post the results. If you decide to go with nitrous and have any questions, let me know, I might be able to help.
