81 - 100 of 103 Posts
Discussion Starter #81
Yeah. I’d love to be able to get the cams. I’m holding off a bit until I get the nitrous system in.
2014 Ford Fiesta SE Hatchback
Cold Air Intake
N2MB Two Step
FRPP Suspension
17” Focal with 205/45s
how big are you going?
150 max. Probably 100-125 to be safe. And it’ll be a wet shot.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #83
Cold Air Intake
N2MB Two Step
FRPP Suspension
so you're essentially wanting to double the output of yours. I'm curious, what are you going to do to pull timing and what are you going to do for extra fuel.
125-150 is max safe for wet system. 75 for a dry shot. ECU will be able to compensate timing up to that. I usually run the fuel solenoid fatter by one or two jet sizes in carbed apps. Lean is mean, but fat is safe.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #85
Cold Air Intake
N2MB Two Step
FRPP Suspension
125-150 is usually what I recommend for v8's (i come from the smallblock world) on 4 cyls i recommended widening ring gap slightly to prevent any accidental touches. Also have you thought of a step colder on your plugs as well? Whats the safe limit for the factory fuel as well? jight wanna upgrade to a 255
Brisk plugs are what I’ll run. Pump upgrade will be in there too.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #87
Cold Air Intake
N2MB Two Step
FRPP Suspension
you should be good. you running an afr?
I will, yes. Which do you recommend?
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #89
Cold Air Intake
N2MB Two Step
FRPP Suspension
I've always ran AEM. youll need it welded before you cat. so I'd recommend getting a header if you dont have to pass a sniff test
I have an OBX Header, so I’m good to go there.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #91
Cold Air Intake
N2MB Two Step
FRPP Suspension
How do you like it? I'm tossing up grabbing one to fix the leak I have at my flex pipe. You have to drop the subframe to install?
No problems after 3ish years. If you have a lift, it’ll go in from the bottom once you find the magic angle. I did cut the stock manicat in half to get that out.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #93
Cold Air Intake
N2MB Two Step
FRPP Suspension
thats not too bad. whenni go to do mine ill just drop the subframe down some and it should fish tight into place. Are there studs to guide the headers on/off? I honestly haven't looked
If I remember correctly, there is a single threaded stud on each end of the head.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #95
Cold Air Intake
N2MB Two Step
FRPP Suspension
okay that'll help a good bit. as long as I can be cheap and horde my beer to myself is always a good time
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #97
on a side note, I decided to go without any useable trunkspace
  • Like
Reactions: Dean72
Back in the late 80s/early 90s, I did the car audio thing. Had a dropped 68 Bug with 4 Fosgate Pro 18s and 4 Fosgate Power 1000s. At 2ohms, those amps put out close to 2500rms each.
I kept spare headlights in stock lol
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter #99
Cold Air Intake
N2MB Two Step
FRPP Suspension
sealed wall I suppose?
I use to own a older power 1000 mosfet, sold it to a collector though. thing was a tank.
I'm also sitting on two alpine 3566's for the right project to put them into
  • Like
Reactions: Dean72
My dad worked at Stroh’s canning plant and the rolled aluminum sheets were on 21” diameter cardboard rolls. I capped each end off with 1” particle board after I cut them down to fit. Probably too much air space, but the Pro 18s did very well. I could empty a full 44oz Slushee cup sitting a foot in front of the Bug lol
Cold Air Intake
N2MB Two Step
FRPP Suspension
