I put it back up cause I had to replace a shot end links. No difference changing the direction of the steering wheel. I tightened down the axle but as was suggested elsewhere and it helped a bit but I think the noise plus the play in and out on the driver side leads me to say it’s going out. Ordered a replacement so we’ll see if they fixed it.
Just chiming in to say I had a similar noise at low speeds (5-20mph) on the driver's side and was convinced my axle/CV was going out, what ended up fixing the problem for me (surprisingly) was tightening the outer tie rod nut and snugging up the shock mount nuts. Probably not the same problem you are having, just for anyone else that might see this.
