Hey everyone, last night I was driving and I went to change gears and the clutch pedal went straight to the floor. No resistance. Is there a reservoir to check for fluid? I’m looking and can’t find it.
Need help figuring this out.
Clutch uses the same reservoir as the brakes. I suspect if you look it will be low and you will have fluid under the transmission from the leak.
