1 - 8 of 8 Posts
Yes it can
1s there a way to test sensor?
use a scanner with live data feed. pay attention to the coolant temperature datafeed.
Any other way, jump it out maybe?
iirc the fan is activated by the pcm, Since your relay and fuse are good and the fan is new, that says its (the pcm) not getting the correct signal therefore its not turning on the fan. running a comprehensive data feed is a good way to tell if the temp sensor is reading correctly.
1 - 8 of 8 Posts
