Hey all, so due to a stupid mistake, I now find myself needing to replace my 2012 se fiestas driver door. I found one in town off of a 2011 sedan model, and am curious if anyone knows if they are interchangeable. The place i would buy it from says the interchange numbers are different, but they look identical. Thanks!
According to everything I've read the front doors are the same. Back doors are not. When you switch doors make sure its an SE model. If not the wiring harness inside the doors are different and need to be switched. Found out when I had to do the same thing as you but it was an SES model door.
