Hello. 2013 manual transmission. A couple times the car felt like the e brake is stuck on after coming to a stop. Had to turn the car off and let it sit to fix the problem. Then the “engine malfunction service engine now” warning and the wrench light pop up and back to feeling like the e brake is on.
I’ve also had problems with filling fuel. The pump keeps clicking off.
Any ideas from these symptoms? I’m being into the shop tomorrow.
Thanks.
The brake problem was an ABS control module.
Check engine was mass air flow sensor.
still fighting the fuel filler problem. Most likely need a new gas tank, but I'm just going to fight it for now.
