**UPDATE** Fiesta SECRET MENU!! *New Video North American Fiesta*
So i was on youtube and found this video. Not sure of everything that it shows but what you can see is: coolant temp in F and C. You can see your Speed in MPH and KPH. (great for testing your speedo accuracy. Mine was dead on) You can see a digital Tach. Pretty cool stuff. Not sure what everything else is. But check out the video. Works perfect. I have the SES with push start. I just pushed the start button while having my finger on the odomoter button thats in the video, but did not start the car at first. Loaded into the TEST menu. Then started the car and played around!!
None of my information was reset after doing this. Everything is just as it was.
Video: YouTube - Ford fiesta mk7 **Secret menu**
Hope this is a good place to post this. If not please move to correct area. THANKS!
**update a friend of mine found all the descriptions of everything! Here is the site: Unlock the Digital Dash on Fords - Free Information
* 1.Shows a Gauge Sweep
* 2. Shows all 8's on the LCD (LCD TEST)
* 3. Illuminates all the bulbs on the dash
* 4. Displays hexadecimal value for ROM level
* 5. Displays the hexadecimal value for EE level
* 6. Shows DTC (Diagnostic Trouble Code)
* 7. Digital Speedometer - mph
* 8. Digital Speedometer - kph
* 9. N/A
* 10. Digital tachometer
* 11.Fuel volume
* 12. Engine coolant temperature
* 13. Battery voltage
* 14. ABS fail
* 15. Electronic brake distribution (EBD) failure
* 16. Illumination
* 17. Crank Sense
**Here is the video of a 2011 Fiesta in North America doing the secret menu
Video of me accessing the menu in my car: YouTube - 2011 Ford Fiesta Secret Test Menu
* 9. N/A
* 11.Fuel volume
* 14. ABS fail
* 16. Illumination
* 17. Crank Sense
