So I have a 2016 Ford Fiesta used.
The phone button stopped working like the day after I got it.
No biggie, I looked up what to do, removed the fuse and all that. But now!
The media button is acting up.
When I switch over to media it only stays for like half a second unless I like hold the button. And when i plug my phone in through the aux it doesnt read and doesnt connect. Any suggestions on what to do next?
Thank you!
My 2011 was acting up. I replaced fuse and all started to work again. Try disconnecting battery and reconnecting it. Those two options worked for me.
Thank you!
I've had the same exact problem. What I did to fix it was disconnect the battery for a few minutes but this worked for about a month and the same problem is happening again, only disconnecting the battery won't fix it.
