Intermittent low oil pressure on first start only!
15636 Views 12 Replies 9 Participants Last post by  lewis22davies
Hi all
Looking for some help and advice on my 2013 ford fiesta mk7 1.5 tdci
So over the last couple of weeks I've have a issue when I start the car FOR THE FIRST TIME IN THE DAY ONLY I get a chime and a message come up saying engine low oil pressue. The message goes off so quick you can't really read it I had to slow it down on my phone to see what it said. The oil light goes out after around 2 second after starting the car.
I took it in for a full service and also a diagnostic no codes were found and nothing historical was showing.
The issue stopped for about a week but its come back again when I first start the car on a morning the chime will go off and message comes up then goes out really quick. Some days it doesn't come up at all.
I've been reading online and can't find anything the only thing I found was about the oil pick up but on the 1lt ecoboost engine
So my thoughts are could this be the pressure sensor problem? But why does this only happen on first start up then won't come back on?
Could there be a issue with the oil pick up and if it worth taking the sump off to check does the 1.5tdci have the same issue as the 1lt were the oil pick up can get blocked.
I'm baffled because it doesn't happen every day and the cars running fine no unwanted engine noise no loss in performance just worried because I don't want to cause any damage to the engine.
Hopefully someone can help me out
Regards
Craig
1 - 13 of 13 Posts
I am having exactly the same issue - the message and light displays only during start up.
I have my car booked in to the garage but was wondering whether you got this resolved and what the outcome was!
Hello i have the same problem on 14tdi 2012 model. Any thoughts?
I am having the same problem. Took it to a garage yesterday. They pressure tested and it was good changed the oil pressure switch and solenoid. Warning was there again this morning. Mechanic did say it could be the filter before the oil pump dirty.
Did you get it sorted?
Yes I hope. Screen before pil pump full of sludge, so replaced the oil pump. Got it back yesterday. Mechanic said everything sounds ok, no warning light. Fingers crossed we have caught it before any damage to the engine.
  • Like
Reactions: 1
Glad you got it sorted does the light go off straight away when starting or is there a delay? Mines been okay but a slight delay in the light going off. Is your car diesel or the ecoboost?
It's an ecoboost and there is no delay.
Hey Chris, How did this end up going for you?
Is the car still running? I seem to be having the same issue as you.
I've got an ecoboost and have the same warning light but with a delay, got it booked in at ford garage
Got the same problem. Been saying this for a couple of months on most startups however when I was driving today it would make the chime regularly but no message or light would display. The message for low engine oil pressure popped up once but quickly disappeared again. I have the 63 1ltr ecotecnic just wondered what you guys found the most probable cause to be?
Hi I’ve also come across this issue today. Has anybody resolved this issue? Some advice what it could be would be great. And cost to rectify. Thanks
I had this problem. It was because of the oil filter incorrectly fitted. There is a lug on the bottom of the filter and it wasn't in the hole correctly 👌
1 - 13 of 13 Posts
