1 - 16 of 16 Posts
I have a knocking noise when I go over bumps in the road. It coming from the passenger side rear only. Its not loud but noticable.
I have a Ford Fiesta 2016 reg. 1.0 eco boost.
My car is only 4 years old so I do not believe it to be ball joints or bushes to be worn out already ?
Any ideas appreciated.
Thanks.
Paul.
Thanks.
Paul.
May want to check the wheel bearings and rear shock. I had a rear wheel bearing go bad at about 110,000 miles and my car was only 3 years old at the time.
2014 Ford Fiesta SE Hatchback
Cold Air Intake
N2MB Two Step
FRPP Suspension
17” Focal with 205/45s
Cold Air Intake
N2MB Two Step
FRPP Suspension
Cheers bud will check it out. Mind you I have only done 30000 miles.
30,000 miles? My guess would be a wheel bearing. I read fairly often where rear wheel bearings are the culprit.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Brill thanks mate. Hope it's not expensive job?
I paid 80USD for parts and labor, but I’d been using that shop for a few years.
Cold Air Intake
N2MB Two Step
FRPP Suspension
Do the simple things first. Check lug nut torque.
Discussion Starter · #10 ·
PROBLEM SOLVED.
Went to garage today. Its was rear coil springs. I replaced both of them. £145 UK pounds.
What was the problem with them?
Cold Air Intake
N2MB Two Step
FRPP Suspension
Discussion Starter · #12 ·
One was worn out and the other one was on its way. So changed them both for balance of the car that was recomended to me by the garage.
I still feel with the car 3 years and 10 months old a bit of a surpize to be worn out after 30,000 miles :unsure:
I agree. That’s actually unusual. I replaced my suspension with a Ford Performance set at 140,000 miles.
Cold Air Intake
N2MB Two Step
FRPP Suspension
I have a problem with my bearings and gearbox in my car. I have 18,000 kl on the clock and they are telling me I need a new gearbox. My fiesta is 2 years and 2 months old.
2015 Fiesta SEL
If you're auto, these Powershift transmissions are known to go bad, with harsh, intermittent shifting and I believe there is/was a class action lawsuit about it. Would consult your local dealer if you haven't already as it may be covered under an extended warranty period. If you're manual, then I'd say you prolly ought to adjust your driving habits if its out at 18k
1 - 16 of 16 Posts
