21 - 27 of 27 Posts
I heard back from the dealer this weekend, the cold clutch-out marbles/rattling sound is "gear rollover", and they say it's totally normal. The OP's noise ended up being something different. I'm about to do a trans fluid change as soon as they fix my leaks, and I'll report back if it quiets it down. The fluid is practically liquid gold.
Was think about doing a fluid change as well. will you go ford fluid or something third party? Going to guess Ford is charging a rediculous price to change manual fluid like other shops. It's easier to change then motor oil and they usually want over $100 and you use probably 1liter of fluid.
Until warranty is up I like to use OEM fluids and parts. I've already stocked up on fluids, filters, and plugs to last me a while. The trans fluid is in the ballpark of $25-30 quart, and I thought GM's Synchromesh was expensive;) The drain & fill plugs are easily accessible, so I'll do that myself.
Discussion Starter · #25 ·
The issue was not resolved,I may have to contact ford customer service for the 2nd time since owning this car to maybe get something taken care of.
If I could cut my losses and give it back and walk away I prob would at this point....and go back to Mazda's.
I may just upgrade to the mountune shifter arm as it should be better even though I don't think I should have to be doing it out of my pocket.
I can get a new case opened for you. Just PM me your VIN, updated mileage, best daytime phone number, full name, and dealer name/location.
Meagan
Hi, my fiesta is developing similar issue. It is intermittent and I can not catch it to film it. Could you please post again YouTube video presenting the noise? Also, did you managed to fix the issue? Thanks
21 - 27 of 27 Posts
