I am ordering the LED parking lamps from the parts dept. for my car. By ordering the Super Fuel Economy package, I boxed myself out of being able to get the LED lights, given the way the options are bundled. The service guy said they should be 'plug & play' and they said if I wanted to buy the lights (and switch probably) they would be happy to install them. The only thing I have to check on before actually ordering the lights is to have a look at what body additions are included on the SFE package that might interfere with their installation. I can't see where that would be a problem, but I have no pictures to base that decision on. I also don't know if there are just plastic plugs in the stock locations, or maybe the hole in the bumper cover is not even cut out. I hope that is not the case. Better to wait until my car comes in and get them then.I've been looking on the ford parts website and can't find the LED lamps to add onto my SE...
does anyone know if they're going to be an orderable part?
I couldn't find them on fordparts.com - do you know what the part number is?you can download the instructions on how to install them on the Ford Accessory site. You can order them from the parts deparment, or from Ford Accessories when they are released. The accessory price should be cheaper than the parts department price.
Thanks BRGT350Part Number: SKBE8J-13K204-AA
Instructions found here: Technical Specifications
From reading through the LED instructions, it doesn't appear as if you have control over them from the dash, they're even called 'supplemental parking lamp' which makes me believe they're only supposed to come on automatically when you've got the parking lamps turned on - from the diagrams this appears to be exactly the case. This entire assembly doesn't even require splicing wires which makes me sad and happy at the same time - by the way if you ever jumper wires, try to find some liquid electrical tape to use, it's far better. (we'll see how the factory assembly works when I get a chance to look at my wife's SES - it was supposed to arrive 2 weeks ago but still no sign of it).Are you folks sure the harness & switch on the dash are still there? Most companies try not to give stuff away.
My '95 Neon was wired for power windows in the front doors, and at the time power windows weren't availble yet. They don't want 212 different harnesses when one with it all the plugs makes it simpler, all the same. Switch will need to come form the parts department.Are you folks sure the harness & switch on the dash are still there? Most companies try not to give stuff away.
All I get from that is a site that asks for a keyword, and no matter what I enter I get nothing.Instructions found here: Technical Specifications
You unfortunately have to use Internet Explorer on all of fords misc websites if you plan on getting anywhere useful.All I get from that is a site that asks for a keyword, and no matter what I enter I get nothing.
Here is a link to the current installation instructions for the led parking lamps:
http://www.fordaccessoriesstore.com/GfaWeb/getFileBlob.do?fileid=955. The document will be out of date if they ever update it, so it's best to go through the steps of actually downloading it. So, if you are able to, launch internet explorer and do the following:
1. Near the top, just under "Technical Specifications":
select type: Installation Instructions (Genuine Ford Accessories)
select description: Electronics
2. a new selection will be added:
Choose Category: Lamps, Lights, and Treatments -- Car
3. Click on
Fiesta (2011-CMY) Parking Lamp Installation Instructions
The ambient lighting can be found in the same place. For those of you without Internet Explorer, you'll have to rely on this (potentially outdated) link:
http://www.fordaccessoriesstore.com/GfaWeb/getFileBlob.do?fileid=926
