I ordered a inch and a half lift kit and will be going back to my steel wheels and I rally my car often anyone know what the biggest tires I can fit on the car would be?
Discussion Starter #2
Like I thought I would be doing more road course stuff but this car is just so good on gravel I can’t help myself
I wouldn't go any wider than 205mm, otherwise you can rub on the fender guards. That's the stock width found on the Fiesta ST and no amount of lift kit would provide extra clearance width-wise. If you keep 15 inch steelies then you can go up to 205 75 R15 which is 3.4" taller than stock. But I would likely go with 205 70 R15 which is about 3/4" shorter to better handle the curves
2012 Fiesta SE Sedan, Ingot Silver, 5 spd, 203A with a leather wrapped wheel swap
