I have a 2014 Ford Fiesta Titanium with the 5-speed manual transmission. Recently I noted in previous posts that I was developing a gear whine in the transmission. Most noticeably in 5th gear.
More recently I have a definite whirling sound in the clutch/transmission. It's been cold and definitely quite noticeable at start-up. After the vehicle is driven and warmed up the noise fades and almost gone.
When started a cold there is a pronounced sound. Actually sounds like a blower or supercharger whine on a big engine.
When I press the clutch pedal in the sound goes away. Gone completely. Let the pedal out it returns.
It can be quite noticeable if in gear while cold and coasting while in gear at lows speed such as stop light to stop light. Once driven for quite awhile, it's barely noticeable.
I still have gear whine in 5th gear. Don't seem any worse. Fluid levels are good. I've been under vehicle, I can't find any leaks or drips from any seals.
Any idea what it might be? Difficulty to fix and price to fix. Seems to me it could be imput shaft of transmission. Sounds is there when in neutral with clutch pedal out. A throw out bearing would make noise if going bad when clutch pedal is pressed in.
As far as operation. Everything seems to function as normal.
