1 - 6 of 6 Posts
I’ve replaced the rear motor mount with an aftermarket solid mount. I can’t seem to find the same for the other two motor mounts. Are they out there and I’m just not seeing them, or is there a way to modify the stock mounts? I’m not worried about vibration as I already have substantially more with just the solid RMM. I did read somewhere (and I’m not sure on which vehicle) about using the 1/2 plastic meat cutting boards to replace or solidify the rubbers. Just not sure if that would apply to the Fiesta.
I couldn’t find any substantial info on the forums here. Thanks in advance.
2014 Ford Fiesta SE Hatchback
Cold Air Intake
N2MB Two Step
FRPP Suspension
17” Focal with 205/45s
Powerflex makes a insert for the upper mount, its pretty solid
I’m planning on upgrading to all powerflex bushings and getting that insert. You like it?
I havent put it in mine yet. but I like my other powerflex bushings though
Which bushings do you have?
rear torsion beam and transmission mount. I had thr non caster correcting ones in my control arms but I upgraded to the ones whiteline offer, also have nolathane for my front control arm bushings. (stiffer than the powerflex yellows)
1 - 6 of 6 Posts
