1 - 7 of 7 Posts
This is my 2017 Ford Fiesta S Hatchback DCT in Oxford White.
Stock
704
I drove it completely stock for a few months then I added an open cone filter:
705
706
The modified intake increased throttle response as well as a noticeable power increase (butt dyno and smoother driving up hills). It also sounds good.
Last year, I started to look for wheels to replace the stock steelies/wheel covers. I found a local selling a used set of black machined wheels that were part of the appearance package. There were some blemishes, but I really liked theses wheels so I picked them up.
Stock wheel:
707
The stock 185/60/15 Hankook Optimos were also replaced with 205/45/16 Firestone Indy 500 Summer tires.
New (to me) Ford black machined 16x6.5 wheels:
708
Next up was adding stiffer springs. I chose Eibach ProKit Lowering Springs 35123.140
An online retailer posted a very low price which was likely a mistake, but I clicked add to cart and the retailer sold it to me at a substantial discount (price immediately returned to its msrp price after my order lol).
These are a progressive rate spring that lower the Fiesta about 1 inch all around.
709
The springs reduced body roll was and the ride is comfortable. I did keep the stock struts and shocks as they didn't have many miles on them yet and Eibach themselves used factory struts to test/design these springs.
The next modification was replacing the stock exhaust system with a stock FiST exhaust system. I found a local parting out their ST so I picked up the exhaust (note that they aren't given away for free in SoCal lol) The ST exhaust will bolt right up. ST exhaust on the left and base Fiesta on the right.
710
The exhaust sound has a nice growl to it and is not too loud at all, instead it sounds sporty on a NA 1.6
Next up was window tinting. I had them put 5% in the rear and 35% in the front.
711
712
Added an Eibach 21mm Rear Sway Bar #35143.312 It reduced body roll during turns a bit, but not much more than the lowering springs had already.
713
Lookin' good. Like the supension mod, thinking of doing the Bilstein setup.
  • Like
Reactions: FiEscort
When you added the rear sway bar, how was the install? Any holes you had to drill since there’s no factory one? Car looks good!
  • Like
Reactions: FiEscort
Thanks. You're referring to the B14 setup? Post up your results if you end up using that setup. I'm planning on using B6 or B8 suspension when these stock struts/shocks give out.
Discussion Starter #7 (Edited)
Thanks. It was pretty straight forward. No drilling was required for the installation. There should be holes right underneath the shocks. You will have to loosen the bolt that goes through the shock and move it out of the way. You then bolt up the sway bar to the holes that are now accessible.
1 - 7 of 7 Posts
