Hi all,
Both of the strings that hold the trunk cargo cover up have had the plastic part break that holds it to the cover. I can't seem to find replacements anywhere (other than UK, I'm in the US), any ideas where to get new ones? They seem simple enough they should be replaceable without buying an entire new cargo cover.
Thanks!
2015 Fiesta SEL
Could rig something up yourself by getting some heavy duty string (boot or shoelaces?) and tying one end around a nut (or anything large enough not to pull through), threading it through a washer (to give strength and support so the nut doesn't pull through the cover), then through the cargo cover before tying a loop in the end that goes to the peg on the liftgate. A bit of backyard engineering, but a little creativity and you can make it look respectable. Good luck! ;)
