Hi, I own a 2013 Fiesta SE. I recently had to have the front windshield replaced and am noticing a lot of dashboard reflection which I never really noticed previously, especially in bright sunlight. Does anyone have a solution for this other than a dash mat? I'm not sure if the dash was wiped down with something that might cause this. I let some dust build up but that is not changing anything. I've done some research on the internet and it seems that the glass is rarely mentioned as the problem but it is usually the color of the dash or the cleaner used on it. My dashboard is dark gray and as I said, I don't remember this being a problem with the original windshield. Thanks!
It sounds like a dash mat may be a good solution. Maybe try getting some sort of cleaner to try to get anything off of the dash that may be causing it to be shinier? Otherwise you could go wild and flock the dashboard but I don't know if it would be worth the effort.
