So like many Fiesta owners with the base Sync system, I think it sucks balls and I’m looking for options. Yes, aftermarket options do exist but they’re more expensive, and don’t look OEM. I decided to research into what exactly it would take to upgrade to Sync 3. I’ll be using this thread as a place to put my findings, and possibily brainstorm with other memebers. I don’t think this is nearly as difficult as some have made it seem.
Ok so there’s roughly 4 components that make up the audio system on these cars (without Sony audio):
APIM (Accessory protocol interface module)- this is the module that handles bluetooth, Sync, USB audio, and communicates with other parts of the car (vehicle system menus, door ajar warnings, etc..). Basically it’s the brains of the infotainment system.
ACM (Audio Control Module)- The “radio”. This is what does the audio processing, plays CD, and receives AM/FM radio and amplifies it to the speakers. As far as I can tell this is the same for both systems and wont need to be changed.
Control panel - Ur buttons
Screen- Self-explanatory
So here’s what I understand so far:
The APIM on base Sync cars is located behind the glovebox, whereas on Sync 3 cars it’s located behind the screen. In fact usually the screen and APIM are sold together in the used market. This is challenge #1 because the harness connector is actually in 2 different places. The good news it it appears to use the same 54pin connector for both versions, however the pin arrangement/configuration is likely to be different. How do we get from under the glove box to behind the screen? With some sort of an extension harness. Sure you can make one, but the female portion of the connector is difficult to source. You could also just get one of these.
https://www.alibaba.com/product-det...ml?spm=a2700.7724838.2017115.1.522569e9YhDKxV
These are meant to add backup camera, but assuming it’s long enough would work well as an extension itself. You would only need to re-arrange the pins which is just really a matter of studying the wiring diagrams for both versions. You’ll also need to extend the USB cable, but that’s just a regular mini-usb cable so any USB extension cable would work. Additionally there’s the FAKRA connector for the GPS, which only drives the compass AFAIK and I think also works with 911 Assist. You can either extend that as well or just get another antenna.
Next thing is the connection between the control panel and and the APIM. I havent verified this but I think both use the same connector. I need to look at wiring diagrams of the two systems to be sure though.
Shopping list (so far):
- Sync 3 APIM/Screen assembly ($100 or so on Ebay)
- Control panel ($35-$50 Ebay)
- Console hood/shroud (probably like $20 or so)
- Extension harness ($15 or so from China)
- USB extension cable ($3 or so from Amazon)
Now for the P-word. Programming. I don’t think there will be much that needs to be done here that can’t be done with Forscan. Yes the APIM wont have the correct VIN# programmed to it, and so what? Who cares. The only thing I can see this causing an issue with is doing a Vehicle health report, which is something I’m willing to give up. There aren’t that many different configurations of our cars where options config would be that big of a difference.
Another thing that gives me conficence. This has been done before. Just not on Fiestas. F150 people have done it, Focus people have done it, and Fusion people have done it, and probably more I just haven’t really looked. Fords ICE systems more or less work the same across all models, just with varying degrees of complexity. The good news is that our cars are relatively simple compared to higher-end models where Sync integrates with the instrument cluster, the climate control (since it’s controlled via touch screen on many of those cars whereas on ours it’s separate), etc.. They somehow managed to figure it out and we wont have half of the issues to deal with since our cars don’t have any of that **** anyway.
There’s some good reading here:
http://www.2gfusions.net/showthread.php?tid=4050
