In the owner's manual, it says that there is an "accessory delay" feature
which allows you to use the power windows, radio, and moon-roof
(if equiped) for 10 minutes after the ignition switch is turned off or
until one of the doors is opened.
I don't have a power moon-roof, and I can work the radio after the
ignition sw. is turned off, but I can't work the power windows after the
switch is turned off.
I also noticed that I can't turn on my headlights unless my key is in
the ignition and it is turned to the "run" position.
I just wondered if all of your cars are set up the same way (regardless
of what the manual says) or if something is turned off in the software of
my car that needs to be turned back on.
Thanks in advance for any responses!
