Has anyone had their CTM go bad? I'm still waiting for Ford to get the part three months in. Any ideas how much longer I might have to wait?
If you have the car, check the ground wire on the battery and see where it is bolted to.
Remove the bolt and if has paint under the lug......boom!
Sand off the paint, replace.
It's a major issue that is being over looked....
It'll clear up the herky jerky starts.... better mpg
Probably have to get the codes cleared.
Good luck
Good luck
Thank you, I'll have to try that, but the main issue is it's reving up to about 4000 before it'll shift into fourth. And occasionally slipping altogether. I'll try to get to it in the morning.
SaffronOrion 😏
