21 - 25 of 25 Posts
Here's the ARP studs on the Fiesta:
They are late model Camaro wheel studs. ARP 100-7708 is the part number. I'm at work and can't go on shopping websites.
Anybody know any good, cheap wheel spacer options for the 2012 fiesta? Can't find any hubcentric ones. And I'm sure I need that lol.
If you're looking for a reputable brand wheel spacer, BONOSS is the way to go. They're very well built and will hold up well. I bought a set used 3 years ago and they're still perfect.
This is what I run, 2019 Fiesta HH SE na 1.6 same for front & back with 195/50R16 84H @ 35psi OEM...
Not a sponsor
"For looks only" ...
clean all mating surfaces, install and torque to spec, install your wheels using your lugs. Re-torque spacers and tires @ 10 miles & again @ 50 miles. check every 500 m until you are confident.
(2) 1 (25mm) Hubcentric Wheel Spacers | 4x108 4x4.25 63.4mm Hub | 12x1.5 Studs
(2) 1" (25mm) Hubcentric Wheel Spacers | 4x108 4x4.25 63.4mm Hub | 12x1.5 Studs
(201921798300)
Quantity : 2
ITEM PRICE:US $77.90
Are the 25mm spacers just on the fence of needing longer studs/vs not? I got a set of 20mm for the rear w/o studs. think I'll be pushing it? Need to wait to get them in and see if I can get at least 7 turns, then I'll be good.
21 - 25 of 25 Posts
