16" Sparco Assetto Gara's
4.9K views 8 replies 4 participants last post by  TeamEpsilonRacing
#1 ·
Bought from tire rack. Will install this weekend and post some pics. So excited!!
Wheels:
16x7 Assetto Gara's matte gunmetal
Tires:
General G-Max AS-03 205's
Petrulak1993's post heavily influenced my decision to go with these over the sport editions in the end.
Discussion starter · #7 ·
Hella 500's which were like $100ish. They come with everything u need as far as wiring fuses switches etc. Once it was all wired up and tested I took off the bumper, measured the holes and drilled it. I am wayyyy over simplifying the process as it took quite some time to get the bumper and everything off. If u want more details I would be happy to provide them.
Discussion starter · #9 ·
It comes with a seperate switch that you must wire in to the supplied relay. I have it set up so that it is independent of the lighting system. You can wire it so that you can only flip the switch on when lowbeams are on. You can also eliminate the switch completely if you choose and have them automatically come on with the lowbeams.
