21 - 28 of 28 Posts
I just recently installed my fog lights from winjet and they came with their own wiring setup but I dont want to go through that hassle since my fiesta 2016 se has the wiring already installed. My ONLY issues is my switch in my car does not have the fog light switch it stops after auto lights. Do i need to buy a switch to turn the lights on or will the lights come on with my normal lights.
just ran up on this post last night thanks so much. I just sat down to do the relay mod for my fog lights then ran up on this post. Ive had my fog lights and switch installed right after I got my car just about 4 years ago. Went this morning to do the FORScan got it working and one light is burned out just my luck lol
Hi.
The search function in the android Tapatalk app isn't great.
Would someone be kind enough to link the thread of the required parts for installing fogs?
Thanks
Sent from my Pixel XL using Tapatalk
Good Stuff
I have a 2019 Fiesta and I ordered the Switch and Fog Lights. I was lost to why they didn't work so I started my Internet search. I came across your post and looked at Forscan YouTube video's as well. My Fog Lights came to life by changing the value to Fog Lights with no restrictions in the IPC Central Configuration (MAIN) with no further actions needed.
Thanks for being a part of the puzzle BIG HIGH FIVE!
When the Ambient aesthetic light switch I ordered comes in I'm bringing that feature to life as well.
Important:
Ok so once I finally installed the fog lights and the switch I realized it wasn't working. I went back in again with Forscan and realized my error. Central config is in 2 places. The IPC, which apparently is the main store, and the BCM, which is the backup. So I did my configuration in the BCM, which seems then it was overwritten again by the IPC. I went back in and did on the IPC, and NOW it's working.
how do you edit the bcm ? its read only
i set it to Fog Lights with no restrictions in the IPC Central Configuration (MAIN) but nothing even with a stock fog switch installed also
Hello from 2021...
I have a Fiesta Trend X 2017.
There is no Aux built. So, I want to buy a Bluetooth module for my car.
Before that, I want to enable the Aux woth Forscan. I have a ELM327 device but I can't understand when I click the Aux setting on Forscan. There are 4 choice to enable Aux. Which one I have to select? Can you help me?
21 - 28 of 28 Posts
