Tire and wheel size
8.5K views 7 replies 5 participants last post by  Cobra348
#1 ·
I just bought a 2013 Fiesta S. I'm loving it! I think its a great deal!
Anyway, I live in Syracuse, NY, the winter is coming soon and snow tires are a must! I find more choices and sometimes better prices in a 185/65-15 instead of the stock 185/60-15. Does anyone think there would be any clearance issues (rubbing and snow build up) going to the 185/65-15 which is .35" bigger in radius?
Also, will 14" rims fit on the car?
Thank you!
#4 ·
Be careful of speedo issues when swapping sizes. Get too far off and you'll be getting tickets when you think you shouldn't be.
I stuck with the 15" size tires. Keep the OEM tires for non-Winter driving and get a good set of Goodyear all-weather radials for Winter. I haven't used snows on any FWD car I've had since 1987 and I'm in the same snow area you are. <points to upper right where my location is>.
I have 2 Fiesta SE sedans ... about mid-November or so, the factory alloy rims will be put on each of them and they both will be running Kelly Optima all-weathers from Goodyear.
#6 ·
I'm not too worried about speedo differences, I almost always look at my GPS for current speed. I swear by snow tires, I used to drive Syracuse-Watertown-Syracuse daily and with snows I could drive twice as fast with more control than all seasons. The only thing that slowed me down was visibility.
Thanks for the feedback about the 185/65-15s. Thats what I'll go for. I was wondering about 14s because I might be able to get some alloy wheels from an escort.
#8 · (Edited)
Here's what I did - as noted I have Kelly tires on the factory alloys. I bought rims from TireRack (a sponsor here). Sport Tuning T5 for the '11 (Phantom) and T10 for the '12 (Cherri).
These rims have either the OEM Kumho 15" tires or a set of high-rating dry/wet tires. Currently this is what is mounted on each car. I'll swap to the other set in November (earlier if needed).
Making the run to Watertown and back, I would recommend true snow tires - I-81 has some nasty stretches that could tax the best snow/ice all-weather tire I think.
